[geos-devel] [GEOS] #982: Postgis ST_ConcaveHull Runtime GEOS Problem?
GEOS geos-trac at osgeo.org
Sun Aug 25 01:21:24 PDT 2019
 Reporter:  tsw         |       Owner:  geos-devel@…
     Type:  defect      |      Status:  reopened
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.7.0
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Changes (by komzpa):
 * status:  closed => reopened
 * resolution:  invalid =>
Comment:
 PostGIS ticket: https://trac.osgeo.org/postgis/ticket/4469
 Here author says he reverted this change and it made no difference for
 him:
 https://www.mail-archive.com/postgis-users@lists.osgeo.org/msg07593.html
 I tried commenting out the line in the ST_ConcaveHull function you
 suggested but that doesn't make a difference. I suspect there is some
 underlying library that has changed.
 @dbaston would be cool if there's a way to express your intention without
 closing tickets as "invalid", as this one is a valid one.
Ticket URL: <https://trac.osgeo.org/geos/ticket/982#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
