[geos-devel] [GEOS] #962: GEOSNode is much slower that GEOSUnaryUnion
geos-trac at osgeo.org
Mon Aug 26 16:09:20 PDT 2019
Reporter: komzpa | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.6.2
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
Here's what I think is going on. `GEOSNode` uses the GEOS
[https://github.com/libgeos/geos/blob/master/src/noding/GeometryNoder.cpp
GeometryNoder], which in turn uses
[https://github.com/libgeos/geos/blob/master/src/noding/IteratedNoder.cpp
IteratedNoder]. `IteratedNoder` uses `MCIndexNoder`, which is actually
O(NlogN)-ish. But the function of `IteratedNoder` is to attempt to fully
node lines by repeatedly re-noding until no new nodes are created. There
are situations involving almost-parallel lines where repeated noding keeps
adding nodes, but also perturbing the resultant line segments so that they
still cross. So this will obviously be very slow.
OTOH the GEOS `UnaryUnion` uses the overlay snapping heuristic if it
detects noding failure. That's probably succeeding here, and so the
computation is faster.
However, in the case DB mentions the UnaryUnion is perhaps hitting the
recent correctness heuristic that was introduced to prevent some other
failures. It seems to be quite slow in some cases. Probably the dataset
does not cause too much (perhaps none) repeated noding in GEOSNode, so
that is faster.
Ticket URL: <https://trac.osgeo.org/geos/ticket/962#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
