[geos-devel] [GEOS] #962: GEOSNode is much slower that GEOSUnaryUnion
geos-trac at osgeo.org
Mon Aug 26 16:12:56 PDT 2019
Reporter: komzpa | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.6.2
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
It is the case that JTS provides the
[https://github.com/locationtech/jts/blob/master/modules/core/src/main/java/org/locationtech/jts/noding/snapround/GeometryNoder.java
GeometryNoder] which uses snap-rounding. That would probably be
reasonably fast and should not have the noding failures (at the price of
having to round all coordinates slightly). The upcoming OverlayNG should
also have this same behaviour and performance. So that will be a medium-
term fix for this. It will be a task to revisit the GEOS noding and make
it utilize the new code.
Ticket URL: <https://trac.osgeo.org/geos/ticket/962#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
