[geos-devel] [GEOS] #588: [JTS fixed] valid polygon when cw, not valid when ccw
geos-trac at osgeo.org
Tue Aug 27 11:17:31 PDT 2019
Reporter: olivier80 | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.8.0
Component: Default | Version: 3.3.5
Severity: Unassigned | Resolution: fixed
Keywords: jtsfail |
Changes (by dbaston):
* status: new => closed
* resolution: => fixed
Comment:
Apparently fixed with robust determinant fixes in 3.8.x. Added regression
test in [changeset:4c8e68a1cf16637be0ef3826c18fc3df628039c8/git]
Ticket URL: <https://trac.osgeo.org/geos/ticket/588#comment:13>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
