[geos-devel] [GEOS] #588: [JTS fixed] valid polygon when cw, not valid when ccw
geos-trac at osgeo.org
Tue Aug 27 11:26:33 PDT 2019
Reporter: olivier80 | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.8.0
Component: Default | Version: 3.3.5
Severity: Unassigned | Resolution: fixed
Keywords: jtsfail |
Comment (by mdavis):
Thanks, DB.
It might be nice to add a comment to the test with this issue number, so
we can understand history?
Ticket URL: <https://trac.osgeo.org/geos/ticket/588#comment:14>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
