[geos-devel] Fix Appveyor badge?
Daniel Baston dbaston at gmail.com
Fri Feb 22 10:41:58 PST 2019
Hi Martin,
You're welcome to link the badge to my AppVeyor account if you'd like. I
just set that up because I wanted to test my own pull requests against
MSVC, and the OSGeo/geos AppVeyor stopped working when the GEOS repository
was moved out of the OSGeo organization. Probably a better solution is for
someone to figure out how to either revive the OSGeo/geos AppVeyor, or to
create a new project-specific AppVeyor account.
Dan
On Fri, Feb 22, 2019 at 12:47 PM Martin Davis <mtnclimb at gmail.com> wrote:
> @dbaston: would it be possible to fix the Appveyor badge to point to the
> current Appveyor CI?
> The badge link is on the wiki and in the README:
> https://trac.osgeo.org/geos/wiki/WikiStart
> https://git.osgeo.org/gitea/geos/geos/src/branch/master/README.md
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20190222/9ebb5f7e/attachment.html>
