[geos-devel] Fix Appveyor badge?
Martin Davis mtnclimb at gmail.com
Fri Feb 22 10:56:08 PST 2019
Agreed, someone should make the GEOS Appveyor setup better.  I'd just like
to get the badge working, so failures are more visible.
Can you provide a URL for the badge?
On Fri, Feb 22, 2019 at 10:42 AM Daniel Baston <dbaston at gmail.com> wrote:
> Hi Martin,
> You're welcome to link the badge to my AppVeyor account if you'd like. I
> just set that up because I wanted to test my own pull requests against
> MSVC, and the OSGeo/geos AppVeyor stopped working when the GEOS repository
> was moved out of the OSGeo organization. Probably a better solution is for
> someone to figure out how to either revive the OSGeo/geos AppVeyor, or to
> create a new project-specific AppVeyor account.
> Dan
> On Fri, Feb 22, 2019 at 12:47 PM Martin Davis <mtnclimb at gmail.com> wrote:
>> @dbaston: would it be possible to fix the Appveyor badge to point to the
>> current Appveyor CI?
>> The badge link is on the wiki and in the README:
>> https://trac.osgeo.org/geos/wiki/WikiStart
>> https://git.osgeo.org/gitea/geos/geos/src/branch/master/README.md
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20190222/88d32524/attachment.html>
