[geos-devel] Fix Appveyor badge?
Daniel Baston dbaston at gmail.com
Fri Feb 22 13:54:27 PST 2019
Hi Martin,
I updated the URLs in the README.md to point to my AppVeyor account.
Dan
On Fri, Feb 22, 2019 at 1:56 PM Martin Davis <mtnclimb at gmail.com> wrote:
> Agreed, someone should make the GEOS Appveyor setup better.  I'd just like
> to get the badge working, so failures are more visible.
> Can you provide a URL for the badge?
> On Fri, Feb 22, 2019 at 10:42 AM Daniel Baston <dbaston at gmail.com> wrote:
>> Hi Martin,
>> You're welcome to link the badge to my AppVeyor account if you'd like. I
>> just set that up because I wanted to test my own pull requests against
>> MSVC, and the OSGeo/geos AppVeyor stopped working when the GEOS repository
>> was moved out of the OSGeo organization. Probably a better solution is for
>> someone to figure out how to either revive the OSGeo/geos AppVeyor, or to
>> create a new project-specific AppVeyor account.
>> Dan
>> On Fri, Feb 22, 2019 at 12:47 PM Martin Davis <mtnclimb at gmail.com> wrote:
>>> @dbaston: would it be possible to fix the Appveyor badge to point to the
>>> current Appveyor CI?
>>> The badge link is on the wiki and in the README:
>>> https://trac.osgeo.org/geos/wiki/WikiStart
>>> https://git.osgeo.org/gitea/geos/geos/src/branch/master/README.md
>>> geos-devel mailing list
>>> geos-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20190222/d29c8d71/attachment.html>
