[geos-devel] Fix Appveyor badge?
Martin Davis
mtnclimb at gmail.com
Fri Feb 22 20:11:19 PST 2019
Thanks. I've updated the badges on the wiki.
On Fri, Feb 22, 2019 at 1:54 PM Daniel Baston <dbaston at gmail.com> wrote:
> Hi Martin,
> I updated the URLs in the README.md to point to my AppVeyor account.
> Dan
> On Fri, Feb 22, 2019 at 1:56 PM Martin Davis <mtnclimb at gmail.com> wrote:
>> Agreed, someone should make the GEOS Appveyor setup better. I'd just
>> like to get the badge working, so failures are more visible.
>> Can you provide a URL for the badge?
>> On Fri, Feb 22, 2019 at 10:42 AM Daniel Baston <dbaston at gmail.com> wrote:
>>> Hi Martin,
>>> You're welcome to link the badge to my AppVeyor account if you'd like. I
>>> just set that up because I wanted to test my own pull requests against
>>> MSVC, and the OSGeo/geos AppVeyor stopped working when the GEOS repository
>>> was moved out of the OSGeo organization. Probably a better solution is for
>>> someone to figure out how to either revive the OSGeo/geos AppVeyor, or to
>>> create a new project-specific AppVeyor account.
>>> Dan
>>> On Fri, Feb 22, 2019 at 12:47 PM Martin Davis <mtnclimb at gmail.com>
>>> wrote:
>>>> @dbaston: would it be possible to fix the Appveyor badge to point to
>>>> the current Appveyor CI?
>>>> The badge link is on the wiki and in the README:
>>>> https://trac.osgeo.org/geos/wiki/WikiStart
>>>> https://git.osgeo.org/gitea/geos/geos/src/branch/master/README.md
>>>> _______________________________________________
>>>> geos-devel mailing list
>>>> geos-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20190222/4c8a1f62/attachment.html>
