[geos-devel] [GEOS] #954: Fix -Wshadow warning in src/algorithm/InteriorPointArea.cpp
geos-trac at osgeo.org
Fri Feb 22 11:13:11 PST 2019
Reporter: rouault | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
I don't see the warning because I'm using clang (OSX). So wondering how
to check for these warnings. Does it show up on one of the buildbots?
This is going to be painful going forward unless we can get this check
happening in all buildchains.
Ticket URL: <https://trac.osgeo.org/geos/ticket/954#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
