[geos-devel] [GEOS] #954: Fix -Wshadow warning in src/algorithm/InteriorPointArea.cpp
geos-trac at osgeo.org
Fri Feb 22 11:16:51 PST 2019
Reporter: rouault | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by rouault):
Ah, I saw this locally with gcc 5.4 of Ubuntu 16.04, but it also showed up
on Travis-CI. For example: https://travis-
ci.com/libgeos/geos/jobs/179892298
We should probably harden bots to enable -Werror
Ticket URL: <https://trac.osgeo.org/geos/ticket/954#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
