[geos-devel] [GEOS] #954: Fix -Wshadow warning in src/algorithm/InteriorPointArea.cpp
geos-trac at osgeo.org
Fri Feb 22 11:45:42 PST 2019
Reporter: rouault | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by rouault):
Unfortunately (or fortunately !) gcc has warnings that clang doesn't have,
and the reverse. Or sometimes they have the same flags, like -Wshadow, but
they don't behave exactly the same, and that also depends on the version
of the compilers... That's the point of having CI testing both...
Ticket URL: <https://trac.osgeo.org/geos/ticket/954#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
