[geos-devel] [GEOS] #954: Fix -Wshadow warning in src/algorithm/InteriorPointArea.cpp
geos-trac at osgeo.org
Mon Feb 25 10:50:34 PST 2019
Reporter: rouault | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
In that case I think we should remove the warnings which can't be
reproduced in all development environments. Otherwise we're going to keep
running into this kind of situation. And I don't think you want to keep
having to create patches for my code.. :)
Ticket URL: <https://trac.osgeo.org/geos/ticket/954#comment:8>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
