[geos-devel] [GEOS] #954: Fix -Wshadow warning in src/algorithm/InteriorPointArea.cpp
GEOS geos-trac at osgeo.org
Mon Feb 25 11:01:45 PST 2019
 Reporter:  rouault     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by dbaston):
 Doesn't Even's suggestion to enable -Werror in our CI solve the
 reproducibility problem?
Ticket URL: <https://trac.osgeo.org/geos/ticket/954#comment:9>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
