[geos-devel] [GEOS] #954: Fix -Wshadow warning in src/algorithm/InteriorPointArea.cpp
geos-trac at osgeo.org
Mon Feb 25 12:52:32 PST 2019
Reporter: rouault | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by dbaston):
You can run CI on your code in a branch before committing it to master and
still be in control. If you decide the failure is because of a problem
with the CI, and you aren't able to fix the CI, you can decide to merge it
anyway.
"Commit first, fix later" can introduce a lot of frustration when multiple
developers are trying to work at the same time. GEOS is not an especially
high-traffic project, but there have certainly been times I've stopped
work because the master branch had build failures.
Ticket URL: <https://trac.osgeo.org/geos/ticket/954#comment:20>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
