[geos-devel] [GEOS] #954: Fix -Wshadow warning in src/algorithm/InteriorPointArea.cpp
geos-trac at osgeo.org
Mon Feb 25 13:00:29 PST 2019
Reporter: rouault | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
I agree with Dan - best to check bots before committing.
AFAIK the only way to do this in GEOS is via a PR on GitHub - is that
right? But that doesn't cover all build platforms, so is not foolproof.
Ticket URL: <https://trac.osgeo.org/geos/ticket/954#comment:21>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
