[geos-devel] [GEOS] #954: Fix -Wshadow warning in src/algorithm/InteriorPointArea.cpp
GEOS geos-trac at osgeo.org
Tue Feb 26 02:21:43 PST 2019
 Reporter:  rouault     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by strk):
 The only way to test _TRAVIS_ is via PRs on GitHub.
 But you can test other bots in other ways.
 Drone can be tested locally with:
   drone exec
 (requires installing drone)
 A PR on the OSGeo GIT infrastructure will automatically
 trigger a Drone build and report status in the commit
 tab (green/yellow/red tiny dot).
 Debbie and Winnie builds I think are only triggered
 by commits to the "master" branch.
 Generally speaking, I think developers are humans so
 don't need bots and should just run:
   make check
 which should run all tests in case of GEOS
 NOTE that every environment may have its own peculiarities
 and thus fail in different way. This means a bot can be
 happy while a Real Human Developer may be blocked by a build
 failure in his/her specific environment (our bots cover
 only a subset of operating systems/architectures).
Ticket URL: <https://trac.osgeo.org/geos/ticket/954#comment:25>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
