[geos-devel] [GEOS] #954: Fix -Wshadow warning in src/algorithm/InteriorPointArea.cpp
geos-trac at osgeo.org
Tue Feb 26 02:25:18 PST 2019
Reporter: rouault | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by strk):
I would not like to be _recommended_ to use a proprietary
service, so please don't force me, as a developer, to file
pull requests on GitHub.
I'm happy with pushing PRs against the official Git hosting
service (OSGeo infrastructure).
The Jenkins service run by Regina if I'm not mistaken does
support building code from Gitea pull requests, only nobody
found the time yet to set it up. Does anyone want to help
Regina with that ?
It would also give us FreeBSD testing.
Ticket URL: <https://trac.osgeo.org/geos/ticket/954#comment:26>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
