[geos-devel] [GEOS] #954: Fix -Wshadow warning in src/algorithm/InteriorPointArea.cpp
GEOS geos-trac at osgeo.org
Tue Feb 26 10:13:43 PST 2019
 Reporter:  rouault     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by mdavis):
 I agree with strk that the ideal is that a dev just has to check their
 local build to see if all is good.  But that's what I've been doing and
 it's not been a great experience so far.
 One issue is that the autotools build is different to the cmake build
 (e.g. check for trailing spaces)
 Another is the one on this ticket - -Wshadow is not in place for OSX
 build.
 So I have to check the bots as well.
 (The REAL ideal would be one build chain and one repo - but that's been
 discussed elsewhere.)
Ticket URL: <https://trac.osgeo.org/geos/ticket/954#comment:27>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
