[geos-devel] [GEOS] #976: Voronoi polygons robustness issue
GEOS geos-trac at osgeo.org
Mon Jul 15 12:08:21 PDT 2019
 Reporter:  komzpa      |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.6.2
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by mdavis):
 This is the place to see if extra precision can provide a more stable
 circumcentre result:
 https://github.com/libgeos/geos/blob/master/src/triangulate/quadedge/QuadEdgeSubdivision.cpp#L424
 The circumcentre call could be replaced with one that uses higher
 precision arithmetic.
Ticket URL: <https://trac.osgeo.org/geos/ticket/976#comment:10>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
