[geos-devel] [GEOS] #976: Voronoi polygons robustness issue
geos-trac at osgeo.org
Mon Jul 15 12:18:30 PDT 2019
Reporter: komzpa | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.6.2
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
Here's a simple test case to reproduce the problem. It's two of the
Delaunay triangles.
GEOMETRYCOLLECTION (POLYGON ((193600.80333333334 469345.355,
193600.80333333334 469345.0175, 193601.10666666666 469345.0175,
193600.80333333334 469345.355)),
POLYGON ((193600.80333333334 469345.355, 193601.10666666666 469345.0175,
193601.10666666666 469345.355, 193600.80333333334 469345.355)))
Computing the circumcentres produces slightly different points:
GEOMETRYCOLLECTION (POINT (193600.95500000002 469345.18625),
POINT (193600.95500000002 469345.18624999997) )
This can be tried with extended-precision to see if it produces identical
points.
Ticket URL: <https://trac.osgeo.org/geos/ticket/976#comment:11>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
