[geos-devel] Inconsistent result of "intersection" function
Martin Davis
mtnclimb at gmail.com
Tue Jul 23 10:24:11 PDT 2019
It would be easier to see what is going on if you post some code that
reproduces the problem.
On Tue, Jul 23, 2019 at 3:35 AM <ritesh.s at intech-dmls.in> wrote:
> Hi,
> We are created polygon and line. After performing the intersection
> function we are getting different values.
> This is the sample code we have implemented using GEOS API (GEOS 3.7.2) .
> Rect = c1.createPolygon(10.78, 10.34, 18.89, 16.64);
> line = c1.makeLine(10.78 , 12.34 ,18.89 , 12.34);
> point = Rect->intersection (line)
> 1. If given line lies on the polygon we are getting the Expected result.
> *Input*: Polygon(10.78, 10.34, 18.89, 16.64);
> *Input: *makeLine (10.78 , 12.34 ,18.89 , 12.34)
> *Current Output from **intersection API :* (10.78 , 12.34) (18.89 ,
> 12.34)
> *Expected Output : *(10.78 , 12.34) (18.89 , 12.34)
> 2. If given line lies away the polygon we are getting the different
> result.
> *Input:* makeLine (8.78 , 12.34 ,20.89 , 12.34)
> *Current Output from **intersection API:* (11 , 12.3.4) (19 , 12.34)
> Can you please suggest why this behaviour diffrence is there in API output.
> Please let me know any additional information needed from my side.
> Thanks,
> Ritesh
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20190723/6796f264/attachment-0001.html>
