[geos-devel] OSGeoLive 13.0 - which version of geos should be installed?
Paul Ramsey
pramsey at cleverelephant.ca
Wed May 1 06:39:26 PDT 2019
I’ll push a patch release out, always good to get changes. Next big release, 3.8, am aiming for the Pg12/PostGIS3 rapture.
P
> On May 1, 2019, at 1:12 AM, Sandro Santilli <strk at kbt.io> wrote:
> Paul, Martin: do you have any plan for a next GEOS release or should
> we tell Astrid to go with 3.7.0 ? I'm guessing 3.7.1 could be nice,
> having these fixes:
> - Envelope constructor using strtod (#875 Paul Ramsey)
> - Failure in CMake for OSX Framework (#936 Paul Ramsey)
> - Polygon build failure in Overlay difference (#789 Paul Ramsey)
> - Invalid union result from valid polygon inputs (#838)
> --strk;
> On Tue, Apr 30, 2019 at 09:00:56AM +0000, astroidex at gmail.com wrote:
>> Hi Sandro, Frank,
>> The OSGeoLive 13.0 build cycle has started and we already have a build.
>> Please download alpha1 version and check your application/data [1]
>> http://aiolos.survey.ntua.gr/gisvm/13.0/osgeolive-13.0alpha1-amd64.iso (3.8
>> GB)
>> http://osprey.ucdavis.edu/downloads/osgeo/gisvm/gisvm/13.0/osgeolive-13.0alpha1-amd64.iso
>> (3.8 GB)
>> Many projects have already updated their software and are included in
>> alpha1. Thank you.
>> You can find a list of software versions at:
>> https://github.com/OSGeo/OSGeoLive/blob/master/CHANGES.txt
>> If your project geos is not available yet, please provide it by 25 June
>> 2019.
>> * please change your installer at Github [2] or provide a package.
>> Key Milestones - see schedule [4]
>> 25-June-2019 OSGeoLive Feature Freeze (final application versions installed)
>> 09-Jul-2019 English Project Overviews & Quickstarts complete (commit your
>> changes on github)
>> Note: our documentation translation has moved to Transifex [3]
>> 16-Jul-2019 OSGeoLive RC stage (documentation release)
>> 23-Jul-2019 Translations complete (translations are done in Transifex) [3]
>> 30-Jul-2019 OSGeoLive Final ISO
>> 26-Aug-2019 FOSS4G 2019 Bucharest, Romania [5]
>> Any questions, please ask on the OSGeoLive mailing list [6] or meet the
>> osgeolive team on irc #osgeolive or contact me directly.
>> Warm regards,
>> Astrid Emde and the OSGeoLive Team
>> [1] http://aiolos.survey.ntua.gr/gisvm/13.0/osgeolive-13.0alpha1-amd64.iso
>> (3.8 GB)
>> [2] https://trac.osgeo.org/osgeolive/wiki/Source_code
>> [3] https://wiki.osgeo.org/wiki/OSGeoLive#Translate
>> [4] https://trac.osgeo.org/osgeolive/wiki/Release%20Schedule
>> [5] http://2019.foss4g.org/
>> [6] https://live.osgeo.org/en/contact.html
