[geos-devel] [GEOS] #966: CMake does not build/test doc/example.cpp
geos-trac at osgeo.org
Thu May 9 09:20:24 PDT 2019
Reporter: dbaston | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.8.0
Component: Build/Install (cmake) | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by strk):
Doesn't really need to... Does autotools do ?
I guess it's enough that "make check" builds it, as it's just a build
test, basically (and nobody should use the C++ interface anyway, would be
about time to have an example.c)
Ticket URL: <https://trac.osgeo.org/geos/ticket/966#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
