[geos-devel] [GEOS] #966: CMake does not build/test doc/example.cpp
GEOS geos-trac at osgeo.org
Thu May 9 09:22:58 PDT 2019
 Reporter:  dbaston                |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  new
 Priority:  major                  |   Milestone:  3.8.0
Component:  Build/Install (cmake)  |     Version:  master
 Severity:  Unassigned             |  Resolution:
 Keywords:                         |
Comment (by dbaston):
 I just noticed it because Travis showed a build failure with autotools,
 which builds example.cpp, but not with CMake. I don't have an opinion on
 whether we provide an example.cpp, but if do provide one we ought to at
 least test that it compiles and runs.
Ticket URL: <https://trac.osgeo.org/geos/ticket/966#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
