[geos-devel] [GEOS] #966: CMake does not build/test doc/example.cpp
GEOS geos-trac at osgeo.org
Thu May 9 10:49:58 PDT 2019
 Reporter:  dbaston                |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  new
 Priority:  major                  |   Milestone:  3.8.0
Component:  Build/Install (cmake)  |     Version:  master
 Severity:  Unassigned             |  Resolution:
 Keywords:                         |
Comment (by strk):
 Agreed about testing it compiles (and sure, why not also run!).
 But has to be done on "make check", to not waste time on
 "make" (it's not meant to be a default target)
Ticket URL: <https://trac.osgeo.org/geos/ticket/966#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
