[geos-devel] [GEOS] #971: @GEOS_VERSION@ not being replaced
geos-trac at osgeo.org
Wed May 22 05:55:43 PDT 2019
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.8.0
Component: Default | Version: master
Severity: Critical | Resolution:
Keywords: |
Comment (by robe):
Correct strk, but it's because of GEOS that debbie's postgis builds are
failing because PostGIS is expecting GEOS 3.6 or greater, and debbie is
running against GEOS trunk (head) and the geos-config that got installed
is all screwed up. No variables got replaced.
this is the output of geos-config that got installed:
#!/bin/sh
prefix=@CMAKE_INSTALL_PREFIX@
exec_prefix=@CMAKE_INSTALL_PREFIX@/bin
libdir=@CMAKE_INSTALL_PREFIX@/lib
usage()
cat <<EOF
Usage: geos-config [OPTIONS]
Options:
[--prefix]
[--version]
[--libs]
[--clibs]
[--cclibs]
[--static-clibs]
[--static-cclibs]
[--cflags]
[--ldflags]
[--includes]
[--jtsport]
EOF
exit $1
if test $# -eq 0; then
usage 1 1>&2
fi
while test $# -gt 0; do
case "$1" in
-*=*) optarg=`echo "$1" | sed 's/[-_a-zA-Z0-9]*=//'` ;;
*) optarg= ;;
esac
case $1 in
--prefix)
echo @CMAKE_INSTALL_PREFIX@
--version)
echo @GEOS_VERSION@
--cflags)
echo -I at CMAKE_INSTALL_PREFIX@/include
--libs)
echo -L at CMAKE_INSTALL_PREFIX@/lib -lgeos- at GEOS_VERSION_MAJOR@
--clibs)
echo -L at CMAKE_INSTALL_PREFIX@/lib -lgeos_c
--cclibs)
--static-clibs)
echo -L at CMAKE_INSTALL_PREFIX@/lib -lgeos_c -lgeos -lm
--static-cclibs)
echo -L at CMAKE_INSTALL_PREFIX@/lib -lgeos -lm
--ldflags)
--includes)
echo @CMAKE_INSTALL_PREFIX@/include
--jtsport)
echo 1.13.0
usage 1 1>&2
esac
shift
done
Ticket URL: <https://trac.osgeo.org/geos/ticket/971#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
