[geos-devel] [GEOS] #971: @GEOS_VERSION@ not being replaced
geos-trac at osgeo.org
Wed May 22 05:57:03 PDT 2019
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.8.0
Component: Default | Version: master
Severity: Critical | Resolution:
Keywords: |
Comment (by robe):
I should add that the geos 3.7 geos-config last installed 5/2 looks like
this, see the difference?
#!/bin/sh
prefix=/var/lib/jenkins/workspace/geos/rel-3.7w64
exec_prefix=${prefix}
libdir=${exec_prefix}/lib
usage()
cat <<EOF
Usage: geos-config [OPTIONS]
Options:
[--prefix]
[--version]
[--libs]
[--clibs]
[--cclibs]
[--static-clibs]
[--static-cclibs]
[--cflags]
[--ldflags]
[--includes]
[--jtsport]
EOF
exit $1
if test $# -eq 0; then
usage 1 1>&2
fi
while test $# -gt 0; do
case "$1" in
-*=*) optarg=`echo "$1" | sed 's/[-_a-zA-Z0-9]*=//'` ;;
*) optarg= ;;
esac
case $1 in
--prefix)
echo ${prefix}
--version)
echo 3.7.3dev
--cflags)
echo -I${prefix}/include
--libs)
# TODO: make an alias for --clibs
# see http://trac.osgeo.org/geos/ticket/497
echo -L${libdir} -lgeos-3.7.3
--clibs)
echo -L${libdir} -lgeos_c
--cclibs)
--static-clibs)
echo -L${libdir} -lgeos_c -lgeos -lm
--static-cclibs)
echo -L${libdir} -lgeos -lm
--ldflags)
echo -L${libdir}
--includes)
echo ${prefix}/include
--jtsport)
echo 1.13.0
usage 1 1>&2
esac
shift
done
Ticket URL: <https://trac.osgeo.org/geos/ticket/971#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
