[geos-devel] Antw: Re: PHP Bindings fir Windows 10 with Wamp and PHP 7.x
Tim Balschmiter
Tim.Balschmiter at rostock.de
Thu May 23 05:02:17 PDT 2019
I´m not sure, if it is the same problem, in my opinion it is an other
way to build php bindings for geos.
I only need a working solution, so i choose every way. It would be my
first extension, which i build. I don´t know which steps and tools i
need.
best regards
>>> Sandro Santilli <strk at kbt.io> 23.05.2019 11:48 >>>
On Wed, May 22, 2019 at 03:03:05PM +0200, Tim Balschmiter wrote:
> Hi Community,
> The php-bindings of Sandro
(https://git.osgeo.org/gitea/geos/php-geos)
> is working finde on my ubuntu system, but i can´t get it work on
Windows
> 10.
Is this the same problem reported on following ticket ?
https://git.osgeo.org/gitea/geos/php-geos/issues/19
> checking whether to enable geos support... yes, shared
> checking for geos-config... yes, shared
> checking for geos-config... no
> configure: error: Cannot find geos_c.h. Please specify correct GEOS
> installation path
> i do not find the place to configure the path for geos_c.h . Maybe
you
> can help me.
$ ./configure --help | grep geos
--enable-geos Enable geos support
--with-geos-config=DIR Use geos-config
Are you passing --with-geos-config switch ?
> In my opinion a lot of people are interessted in a solution ;-).
If you think this is the same problem reported in issues/19 please
update it as you find more things.
> p.s. i only need it for desktop pc, where i can not change the OS.
Virtual machines are easy nowadays :)
--strk;
geos-devel mailing list
geos-devel at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/geos-devel
