[geos-devel] [GEOS] #585: mingw64 trunk make check fail on badthreadtest
GEOS geos-trac at osgeo.org
Fri May 24 11:49:23 PDT 2019
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  minor       |   Milestone:  3.8.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Changes (by robe):
 * status:  reopened => closed
 * resolution:   => fixed
 * milestone:  GEOS Fund Me => 3.8.0
Comment:
 I switched to CMake a while ago, but anyway autotools is working again as
 a result of recent changes in the past 10 days, soo we can close this one
 out as fixed in 3.8
Ticket URL: <https://trac.osgeo.org/geos/ticket/585#comment:18>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
