[geos-devel] [GEOS] #518: GEOS 3.3.2 crashes on MinGW64
geos-trac at osgeo.org
Fri May 24 11:55:39 PDT 2019
Reporter: esseffe | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.8.0
Component: Default | Version: 3.3.2
Severity: Unassigned | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
* milestone: GEOS Fund Me => 3.8.0
Comment:
I suspect this issue might be fixed in 3.8. I get a clean autotools build
and make check now with xmltester under autotools.
It's now cmake where I'm having issue. I think Sandro Furieri (esseffe)
was using autotools for building, so I suspect the issue is probably fixed
for him.
Sandro, can you try retesting and reopen if its still an issue in 3.8.
Feel free to reopen if it is.
We won't be back porting any changes though so will only work for 3.8+
Ticket URL: <https://trac.osgeo.org/geos/ticket/518#comment:9>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
