[geos-devel] [GEOS] #913: mingw64 gcc 8.1 autotools
GEOS geos-trac at osgeo.org
Fri May 24 12:15:16 PDT 2019
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.8.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 This problem got fixed as a result of changes done in past 2 weeks.  Not
 sure what fixed it but -- yeh I can compile and regress fine again using
 autotools with mingw64 + gcc 8.1.0
Ticket URL: <https://trac.osgeo.org/geos/ticket/913#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
