[geos-devel] [GEOS] #1006: CMake build without tests regression
geos-trac at osgeo.org
Fri Nov 29 23:49:06 PST 2019
Reporter: Mike Taves | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Build/Install (cmake) | Version: master
Severity: Unassigned | Keywords:
Prior to GEOS 3.8.0, building tests could be disabled using:
cmake -DCMAKE_BUILD_TYPE=Release -DGEOS_ENABLE_TESTS=OFF ..
With the modern CMake setup for GEOS 3.8.0 (nice work, btw!) this should
be done using:
cmake -DCMAKE_BUILD_TYPE=Release -DBUILD_TESTING=OFF ..
however:
CMake Error at doc/CMakeLists.txt:16 (target_include_directories):
Cannot specify include directories for target "test_geos_unit" which is
not
built by this project.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1006>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
