[geos-devel] [GEOS] #1006: CMake build without tests regression
GEOS geos-trac at osgeo.org
Fri Nov 29 23:50:15 PST 2019
 Reporter:  Mike Taves             |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  new
 Priority:  major                  |   Milestone:
Component:  Build/Install (cmake)  |     Version:  master
 Severity:  Unassigned             |  Resolution:
 Keywords:                         |
Comment (by Mike Taves):
 See fix with !GitHub PR https://github.com/libgeos/geos/pull/251
Ticket URL: <https://trac.osgeo.org/geos/ticket/1006#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
