[geos-devel] GEOS 3.7.3, 3.6.4, 3.5.2 Released
Paul Ramsey
pramsey at cleverelephant.ca
Fri Oct 4 15:40:23 PDT 2019
The stable branches of GEOS have all had patch releases today!
https://trac.osgeo.org/geos/ <https://trac.osgeo.org/geos/>
Changes in 3.5.2
2019-10-04
- Bug fixes / improvements
- Fix crash in GEOSUnaryUnion with empty LineString (#928, Sergey Fedoseev)
- Polygon build failure in Overlay difference (#789, Paul Ramsey)
- Performance improvement in overlay (#986, Paul Ramsey)
- Fix infinite loop in GEOSClipByRect (#865, Dan Baston and Raúl Marín)
Changes in 3.6.4
2019-10-04
- Fix incorrect error return values in GEOSLength and
GEOSisValidDetail (#941, Dan Baston)
- Envelope constructor use strtod (#875)
- Polygon build failure in Overlay difference (#789 Paul Ramsey)
- Invalid union result from valid polygon inputs (#838)
- Static library does not contain C API (#878)
- Prevent crash when querying empty STRtree (#730)
- Overlay performance improvement (#986, Paul Ramsey)
Changes in 3.7.3
2019-10-04
- Union performance regression (#867, Paul Ramsey)
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20191004/96be7941/attachment.html>
