[geos-devel] [GEOS] #994: Segfault in UnaryUnionOp (::buildGeometry, something with C++ strings!)
GEOS geos-trac at osgeo.org
Mon Oct 7 01:55:24 PDT 2019
 Reporter:  strk        |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  blocker     |  Milestone:
Component:  Default     |    Version:  master
 Severity:  Unassigned  |   Keywords:
 #0  0x00007f52990da583 in std::__cxx11::basic_string<char,
 std::char_traits<char>, std::allocator<char> >::_M_dispose()
 (this=0x7ffde4bb7940)
     at /usr/include/c++/7/bits/basic_string.h:220
 #1  0x00007f52990da583 in std::__cxx11::basic_string<char,
 std::char_traits<char>, std::allocator<char> >::~basic_string()
 (this=0x7ffde4bb7940, __in_chrg=<optimized out>) at
 /usr/include/c++/7/bits/basic_string.h:647
 #2  0x00007f52990da583 in
 geos::geom::GeometryFactory::buildGeometry<__gnu_cxx::__normal_iterator<geos::geom::Point
 const**, std::vector<geos::geom::Point const*,
 std::allocator<geos::geom::Point const*> > >
 >(__gnu_cxx::__normal_iterator<geos::geom::Point const**,
 std::vector<geos::geom::Point const*, std::allocator<geos::geom::Point
 const*> > >, __gnu_cxx::__normal_iterator<geos::geom::Point const**,
 const*> > >) const (toofar=..., from=..., this=<optimized out>)
     at ../../../include/geos/geom/GeometryFactory.h:391
 #3  0x00007f52990da583 in geos::operation::geounion::UnaryUnionOp::Union()
 (this=0x7ffde4bb7940) at UnaryUnionOp.cpp:85
Ticket URL: <https://trac.osgeo.org/geos/ticket/994>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
