[geos-devel] [GEOS] #986: Use std::array instead of std::vector in TopologyLocation.cpp
geos-trac at osgeo.org
Fri Sep 13 11:05:49 PDT 2019
Reporter: pramsey | Owner: geos-devel@…
Type: enhancement | Status: new
Priority: major | Milestone: 3.5.3
Component: Default | Version: 3.5.1
Severity: Unassigned | Resolution:
Keywords: |
Comment (by Paul Ramsey <pramsey@…>):
In [changeset:"dfea6aaac4af05800e1806fb99292ca943ac2d5a/git" dfea6aa/git]:
#!CommitTicketReference repository="git"
revision="dfea6aaac4af05800e1806fb99292ca943ac2d5a"
Change from std::array to int[]
References #986
Ticket URL: <https://trac.osgeo.org/geos/ticket/986#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
