[geos-devel] [GEOS] #986: Use std::array instead of std::vector in TopologyLocation.cpp
GEOS geos-trac at osgeo.org
Fri Sep 13 11:11:42 PDT 2019
 Reporter:  pramsey      |       Owner:  geos-devel@…
     Type:  enhancement  |      Status:  new
 Priority:  major        |   Milestone:  3.5.3
Component:  Default      |     Version:  3.5.1
 Severity:  Unassigned   |  Resolution:
 Keywords:               |
Comment (by Paul Ramsey <pramsey@…>):
 In [changeset:"781fab7f6ff0ee4c3beb80be57391738c270e71f/git" 781fab7/git]:
 #!CommitTicketReference repository="git"
 revision="781fab7f6ff0ee4c3beb80be57391738c270e71f"
 Change from using std::array to int[]
 References #986
Ticket URL: <https://trac.osgeo.org/geos/ticket/986#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
