[geos-devel] [GEOS] #988: Doxygen error check with cmake build
GEOS geos-trac at osgeo.org
Sun Sep 15 22:32:39 PDT 2019
 Reporter:  nila                   |       Owner:  geos-devel@…
     Type:  enhancement            |      Status:  new
 Priority:  major                  |   Milestone:
Component:  Build/Install (cmake)  |     Version:  master
 Severity:  Unassigned             |  Resolution:
 Keywords:                         |
Comment (by strk):
 I'm ok to ignore 'not documented' errors via Doxygen flags, if supported
 by Doxygen 1.2.15.
 I used the grep because it was guaranteed to work w/out having to do too
 much research...
 Error out on warning would only be possible when all warnings are fixed, I
 was going there incrementally
Ticket URL: <https://trac.osgeo.org/geos/ticket/988#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
