[geos-devel] [GEOS] #988: Doxygen error check with cmake build
geos-trac at osgeo.org
Mon Sep 16 05:01:15 PDT 2019
Reporter: nila | Owner: geos-devel@…
Type: enhancement | Status: new
Priority: major | Milestone:
Component: Build/Install (cmake) | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by nila):
As I suspected @strk, but didn't want to put words in your mouth. And I
agree. Better to keep all warnings in logfile, what's hidden is forgotten.
I made a small change in the error check cmake-script, which states in
build log how many warnings had been issued:
e.g.
{{{-- Doxygen issued 1702 warning(s), see
/home/travis/build/libgeos/geos/_build/doc/doxygen.log}}}
regardless if the build succeeds or not.
I've tested reverting the Doxygen.in file to version 1.8.8, and setting
WARN_IF_UNDOCUMENTED to NO. Building with 1.8.15 didn't issue any
warnings, so this could be a way to go, but in the future obsolete tags
might appear as well, so... For now, I think we should decide what
warnings we can allow to be ignored.
@dbaston I opened a PR on github as well
[https://github.com/libgeos/geos/pull/224], with intentional doxygen
errors and the {{{doxygen-checked}}} target activated on travis, and the
build failed as expected:
Built target docs
Scanning dependencies of target doxygen-checked
CMake Error at check_doxygen_errors.cmake:42 (message):
/home/travis/build/libgeos/geos/include/geos/noding/SegmentNode.h:70:
warning: argument 'THISISCOMPLETELYWRONGTOO' of command @param is not
found
in the argument list of geos::noding::SegmentNode::SegmentNode(const
NodedSegmentString &ss, const geom::Coordinate &nCoord, size_t
nSegmentIndex, int nSegmentOctant)
/home/travis/build/libgeos/geos/include/geos/planargraph/Edge.h:88:
warning: argument 'THISISCOMPLETELYWRONG' of command @param is not found
in
the argument list of geos::planargraph::Edge::Edge(DirectedEdge *de0,
DirectedEdge *de1)
parameter 'de0'
parameter 'de1'
doc/CMakeFiles/doxygen-checked.dir/build.make:57: recipe for target
'doc/CMakeFiles/doxygen-checked' failed
make[3]: *** [doc/CMakeFiles/doxygen-checked] Error 1
CMakeFiles/Makefile2:1888: recipe for target 'doc/CMakeFiles/doxygen-
checked.dir/all' failed
make[2]: *** [doc/CMakeFiles/doxygen-checked.dir/all] Error 2
CMakeFiles/Makefile2:1895: recipe for target 'doc/CMakeFiles/doxygen-
checked.dir/rule' failed
make[1]: *** [doc/CMakeFiles/doxygen-checked.dir/rule] Error 2
Makefile:795: recipe for target 'doxygen-checked' failed
make: *** [doxygen-checked] Error 2
The command "./tools/ci/script.sh" exited with 2.
Now, it should be tested on Windows too (I've tested on macOS). @dbaston,
could you please help out with this?
Ticket URL: <https://trac.osgeo.org/geos/ticket/988#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
