[geos-devel] [GEOS] #988: Doxygen error check with cmake build
geos-trac at osgeo.org
Thu Sep 26 02:48:50 PDT 2019
Reporter: nila | Owner: geos-devel@…
Type: enhancement | Status: new
Priority: major | Milestone:
Component: Build/Install (cmake) | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by nila):
As [https://github.com/libgeos/geos/pull/224#discussion_r324756010
suggested] by @dbaston I made the doxygen error check a cmake test
(instead of a new build target). I have now cleaned up commit history and
removed intentional test-bugs. Build test on travis works fine (although
at the moment doxygen errors cause failure, something
[https://git.osgeo.org/gitea/geos/geos/pulls/97 PR#97] probably will
solve).
As the test is only executed with doxygen installed, it will not affect
present Windows or macOS CI builds. It might not be too great a risk to go
for this before further testing and deal with eventual problems as they
present themselves?!
As I see it, the PR is now ready for merge.
Ticket URL: <https://trac.osgeo.org/geos/ticket/988#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
