[geos-devel] Compiling geos on windows
Daniel Baston
dbaston at gmail.com
Thu Sep 19 13:23:20 PDT 2019
Hi Paul,
I suspect you're running into the same problem documented in this ticket:
https://trac.osgeo.org/geos/ticket/975
I think the CI builds are succeeding because they have
-DBUILD_SHARED_LIBS=NO.
We probably need to build shared libraries in the CI builds. I haven't
fixed it because I don't have ready access to Windows or Visual Studio.
If you're able to submit a PR to fix this, it would be most welcome.
Thanks,
Dan
On Thu, Sep 19, 2019 at 4:08 PM Paul van der Linden <
paul.doskabouter at gmail.com> wrote:
> Hi,
> I'm trying to compile it on windows (7) in visual studio, but I keep
> getting errors about attempting to reference a deleted function (C2280).
> After quite some digging I found out that the usage of
> std::vector<std::unique_ptr<SomeType>> was the cause of that. (Commenting
> out that declaration and all its references got me a successful compile).
> Tried it in vs2017 and vs2019, same results...
> Both attempts done via the cmake support that has been built in in visual
> studio (just open the folder containing the cmakelists.txt).
> Strange thing is that in your ci builds just fine with vs2019, 2017 and
> even 2015.
> Checking the logs, the only difference I see is that in the ci, and
> enterprise version is used, while I have the community edition. Find it
> hard to believe that those 2 have different compilers...
> Also tried running cmake (latest version), but that kept on complaining
> that it couldn't find it's root and couldn't find CMakeDependentOption.
> Has anyone experience with building in visual studio, or any pointers on
> how to get this to work?
> Will be greatly appreciated.
> Paul
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20190919/1c14a78e/attachment.html>
