[geos-devel] Compiling geos on windows
Howard Butler howard at hobu.co
Fri Sep 20 08:40:49 PDT 2019
I made a PR that fixes these issues. It can be found at
https://github.com/libgeos/geos/pull/226
On Thu, Sep 19, 2019 at 3:23 PM Daniel Baston <dbaston at gmail.com> wrote:
> Hi Paul,
> I suspect you're running into the same problem documented in this ticket:
> https://trac.osgeo.org/geos/ticket/975
> I think the CI builds are succeeding because they have
> -DBUILD_SHARED_LIBS=NO.
> We probably need to build shared libraries in the CI builds. I haven't
> fixed it because I don't have ready access to Windows or Visual Studio.
> If you're able to submit a PR to fix this, it would be most welcome.
> Thanks,
> Dan
> On Thu, Sep 19, 2019 at 4:08 PM Paul van der Linden <
> paul.doskabouter at gmail.com> wrote:
>> Hi,
>> I'm trying to compile it on windows (7) in visual studio, but I keep
>> getting errors about attempting to reference a deleted function (C2280).
>> After quite some digging I found out that the usage of
>> std::vector<std::unique_ptr<SomeType>> was the cause of that. (Commenting
>> out that declaration and all its references got me a successful compile).
>> Tried it in vs2017 and vs2019, same results...
>> Both attempts done via the cmake support that has been built in in visual
>> studio (just open the folder containing the cmakelists.txt).
>> Strange thing is that in your ci builds just fine with vs2019, 2017 and
>> even 2015.
>> Checking the logs, the only difference I see is that in the ci, and
>> enterprise version is used, while I have the community edition. Find it
>> hard to believe that those 2 have different compilers...
>> Also tried running cmake (latest version), but that kept on complaining
>> that it couldn't find it's root and couldn't find CMakeDependentOption.
>> Has anyone experience with building in visual studio, or any pointers on
>> how to get this to work?
>> Will be greatly appreciated.
>> Paul
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20190920/0f6beb9c/attachment-0001.html>
