[geos-devel] [GEOS] #591: Port robust determinant fixes from JTS
GEOS geos-trac at osgeo.org
Fri Sep 20 16:07:59 PDT 2019
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.8.0
Component:  Default     |     Version:  3.3.5
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by Paul Ramsey <pramsey@…>):
 In [changeset:"842593ebd97c5c6380421e0f10e08966269cea5e/git" 842593e/git]:
 #!CommitTicketReference repository="git"
 revision="842593ebd97c5c6380421e0f10e08966269cea5e"
 Add robust determinant test files
 References #591
Ticket URL: <https://trac.osgeo.org/geos/ticket/591#comment:17>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
