[geos-devel] [GEOS] #591: Port robust determinant fixes from JTS
GEOS geos-trac at osgeo.org
Fri Sep 20 16:08:41 PDT 2019
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.8.0
Component:  Default     |     Version:  3.3.5
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Test cases pass and ttmath was added in the fall.
Ticket URL: <https://trac.osgeo.org/geos/ticket/591#comment:18>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
