[geos-devel] VS Studio Help?
Paul Ramsey pramsey at cleverelephant.ca
Mon Aug 3 19:41:29 PDT 2020
Thank you!!!
I see this pattern in other parts of the code base, I just never understood
it.
On Sun, Aug 2, 2020 at 4:04 PM Andrew Bell <andrew.bell.ia at gmail.com> wrote:
> I've got this fixed. I'll push something tomorrow.
> On Sun, Aug 2, 2020 at 1:23 PM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> Bringing in the namespace did not seem to be the trick.
>> https://dev.azure.com/libgeos/geos/_build/results?buildId=596&view=logs&j=305851a9-a7bb-55db-0042-7e2b6f48aa1c&t=7382dcd6-bc22-5ed4-59fb-7b403df8dc96&l=1064
>> https://github.com/libgeos/geos/blob/master/include/geos/operation/overlayng/OverlayGraph.h#L65
>> Still mysterious to me.
>> P
>> > On Jul 31, 2020, at 2:03 PM, Andrew Bell <andrew.bell.ia at gmail.com>
>> wrote:
>> > The CoordinateSequence there doesn't appear to be in the correct
>> namespace. Seems like you would need geom::CoordinateSequence.
>> > On Fri, Jul 31, 2020 at 3:34 PM Paul Ramsey <pramsey at cleverelephant.ca>
>> wrote:
>> > Er, here's the line it's complaining about.
>> > > On Jul 31, 2020, at 12:27 PM, Paul Ramsey <pramsey at cleverelephant.ca>
>> wrote:
>> > > That maybe was a lot of them? I put actual headers into place where a
>> std::vector<std::unique_ptr<>> was being declared, but I'm still left with
>> https://dev.azure.com/libgeos/geos/_build/results?buildId=591&view=logs&j=305851a9-a7bb-55db-0042-7e2b6f48aa1c&t=7382dcd6-bc22-5ed4-59fb-7b403df8dc96&l=156
>> > > and a handful of others. The error seems the same, but I've already
>> brought in the class defn, not sure what else to do...
>> > > P
>> > >> On Jul 31, 2020, at 10:51 AM, Andrew Bell <andrew.bell.ia at gmail.com>
>> wrote:
>> https://stackoverflow.com/questions/34627874/c11-container-of-unique-ptr-of-forward-declared-class
>> > >> On Fri, Jul 31, 2020 at 12:26 PM Paul Ramsey <
>> pramsey at cleverelephant.ca> wrote:
>> > >> We've got a CI failure in MSVC and it's totally opaque. Anyone have
>> a MSVC build environment and ability to look at what's up?
>> https://dev.azure.com/libgeos/geos/_build/results?buildId=585&view=logs&j=305851a9-a7bb-55db-0042-7e2b6f48aa1c&t=7382dcd6-bc22-5ed4-59fb-7b403df8dc96
>> > >> Thanks!
>> > >> P
>> > >> _______________________________________________
>> > >> geos-devel mailing list
>> > >> geos-devel at lists.osgeo.org
>> > >> https://lists.osgeo.org/mailman/listinfo/geos-devel
>> > >> Andrew Bell
>> > Andrew Bell
> Andrew Bell
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20200803/21a3ca97/attachment.html>
