[geos-devel] Renaming TestFunction* to TestOverlay as per JTS change ?
Martin Davis
mtnclimb at gmail.com
Mon Aug 17 11:50:48 PDT 2020
Ah, no, no particular policy on CRs in JTS files. Has not been an issue
there so far.
On Mon, Aug 17, 2020 at 11:42 AM Sandro Santilli <strk at kbt.io> wrote:
> On Mon, Aug 17, 2020 at 11:15:00AM -0700, Martin Davis wrote:
> > It was just a rename, to better identify what tests are in the files.
> > Good idea to mirror in GEOS - thanks.
> The mirroring process currently requires stripping carriage-returns
> from the files. Is there a strict policy on carriage-returns in the
> JTS source files ?
> --strk;
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20200817/7e24569d/attachment.html>
