[geos-devel] [GEOS] #1043: [OverlayNG] tests/general/TestOverlayLL.xml fails
GEOS geos-trac at osgeo.org
Mon Aug 17 11:42:07 PDT 2020
 Reporter:  strk        |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  major       |  Milestone:  3.9.0
Component:  Default     |    Version:  master
 Severity:  Unassigned  |   Keywords:
 A simple test is failing with --overlay-ng. Passes with JTS:
         Description: LrL - LinearRing bug
         Geometry A: LINEARRING (0 0, 0 5, 5 5, 5 0, 0 0)
         Geometry B: LINESTRING (2 2, 5 5)
         Expected result: POINT (5 5)
         Obtained result: LINESTRING EMPTY
 The test is in the tests/general/TestOverlayLL.xml file
Ticket URL: <https://trac.osgeo.org/geos/ticket/1043>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
