[geos-devel] [GEOS] #1043: [OverlayNG] tests/general/TestOverlayLL.xml fails
geos-trac at osgeo.org
Mon Aug 17 12:41:42 PDT 2020
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by strk):
Adding debugging to the OverlayNG GEOS class I'm seeing this graph:
OverlayNG::extractResult: graph: OGRPH
NODEMAP [2]
2 2 OE( 2 2 .. 5 5 ) A:e/B:eL / Sym: A:e/B:eL
5 5 OE( 5 5 .. 2 2 ) A:e/B:eL / Sym: A:e/B:eL
EDGES [2]
The JTS class does not have a toString method, so not sure how to compare
(should add one).
Ticket URL: <https://trac.osgeo.org/geos/ticket/1043#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
