[geos-devel] [GEOS] #1043: [OverlayNG] tests/general/TestOverlayLL.xml fails
geos-trac at osgeo.org
Mon Aug 17 12:47:44 PDT 2020
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by strk):
Changing the LINEARRING type to a POLYGON or LINESTRING fixes the test, so
this seems to be a simple bug which was fixed in old OverlayOP but not the
new OverlayNG
Ticket URL: <https://trac.osgeo.org/geos/ticket/1043#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
